Hello everybody,
Can anyone help me in getting out this, My project includes the acquisition and analysis of gamma rays. So, I require a DAQ card to acquire these gamma rays(pulses).
Coming to the characteristics of these pulses
1. Rise time of the pulse = 0.1micro second
2. Fall time (Decay time) = 1 micro second
3. Average pulse rate <= 5000 pulses/second.
4. Amplitude of the pulse will varying between 0 to 5V/(10V variable)
I am using Proportional counter for these pulses detection, the characterisitcs of the pulse are obtained only after signal conditioning what i had.
Analysis of these pulses include two processes
1. Pulse height Analysis.
2. Multichannel scalar(MCS).
1. Pulse height analysis
In this process spectrum of the acquired pulses should be constructed, which contains the peaks. After obtaining the spectrum, we need to select a gamma ray peak over certain amplitude interval. This is known as pulse height analysis and selection of peak. So, from this process pulses of 5v will be obtained which are spaced randomly.
2. Multi channel scalar(MCS)
In this process the pulses obtain from the pulse height analysis should be counted as a function of external variable in the MCS mode of operation.
In this MCS mode of operation, data(pulses) should be stored into 2000 channels (preset channel no's) by recording the data for 100micro seconds in each channel. This cycle should be completed in 1/10 second. The trigger pulse to start this experiment (MCS mode of operation for data logging) will also initiate a square wave for a period 10hz. The data should be collected for over 600 sweeps and should be filed as a seperate data set.
So, for this process to be done using LabVIEW I need the DAQ card details and the appropriate functions for the analysis. I request the person who is going to provide solution, please provide the details of DAQ card and the functions required.
Thanks in Advance
A.Giridhar Yadav
