Storing and using arrays with case function
I am connected to an insturment which whenever I send a trigger I output an array to my labview code. I can currently see the array that is sent to labview. I would like to be able to use a boolean switch to capture and store an output array whenever the boolean switch value is true. I would then use this stored array to do calculations. If the boolean value is false it does not matter what happens to the array.
(2,715 Views)
Why don't you try to move the data to another array every time the switch is hit. So instead of having one array create 2. One array that is the data you are aquiring and the second array is the data you are storing. When the switch is hit true "true case of the case structure" transfer the data to the 2 array. You can do this with a build array and a shift register in a while loop that is around your acquisition. Hope this helps.
BJD1613
Lead Test Tools Development Engineer
Philips Respironics
Certified LV Architect / Instructor
(2,715 Views)
Hello RS232 Question,
Thank you for contacting National Instruments.
You have a similar post with a different answer at the following link:
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=506500000008000000C0C10000&UCATEGORY_0=_49_%24_6_&UCATEGORY_S=0
Have a great day.
Sean C.
(2,715 Views)
