Real time feedback control using E series DAQ
I am doing real time feedback control(PID)that controls (drives) the up/down motion of Z-piezo in atomic force microscope (AFM) using a E series DAQ NI6025E.I collect a single scan of data from the AFM, perfom some analysis on it,update the driving signal based on a measured value and send out the updated signal to the AFM. I am having problems with synchronisation. Which is the best sync. mechanism (trying to use AI START SCAN VI- using PFI7 pin of E series DAQ).
(2,750 Views)
Sandhya,
You might want to check this post out:
Real Time Feedback using NI 6025E
I believe it addresses the same issue. Good luck! If you have any further questions please post back.
Craig H.
(2,750 Views)
