Store measurement data in the cloud with LabVIEW via REST API
Hi everyone, is there a basic tutorial on how to use LabVIEW to address a REST API to store measurement data in a cloud?
Thank you for your hints and tips.
Greetings Michael
(2,878 Views)
(2,845 Views)
Thanks a lot. I will have a look.
Michael
(2,838 Views)
Depending on your requirements, you might also be able to simply use the built-in HTTP Client VIs under the Data Communication palette.
Some documentation is available here.
The documentation likes to keep leading back to LabVIEW applications being the server (i.e. a webservice), but this isn't required for these VIs to be useful (and it sounds like it isn't the case in your application/system).
GCentral
(2,805 Views)
