Store 1st iteration value
@Paige5 wrote:
My problem is that I am reading from an array, so I need to use a for loop. I want the first value of the array to be subtracted from every other value as it comes in.
Thank you all very much for your help!
Look ma, no loop
"Should be" isn't "Is" -Jay
Message 11 of 13
(2,038 Views)
Accepted by Paige5
Your code is pure Rube Goldberg. Your use of "select" can be replaced by a wire. You can use "delete from array" to get the first element and an array of the rest. Autoindex on the rest after subtracting the first  to play the values in a slow loop or whatever you need to do.
Message 12 of 13
(2,035 Views)
Thank you!
Message 13 of 13
(2,001 Views)
