Stop button
I would like my stop button to essentially "jump" out of 2 loops and execute the code at the end. I tried a case structure but this only worked to exit one for loop and not both of them.
Additionally, i also read theres a way to run program on startup instead of pressing the run button, how is this done?
(5,700 Views)
Accepted by topic author newman3108
Enable the conditional terminal on the for loop and check if the button is pressed and exit if it is.
Certified LabVIEW Architect
(5,691 Views)
So are you looking to end your loop early?  If that is the case, then you can right-click on your FOR loop and then enable the Conditional Terminal.
Build an executable.
(5,690 Views)
While building an executable is the preferred way (but you need the app builder for that!), there is also a vi option to "run when opened".  (This works when opening from windows explorer, but not from within a project)
(5,647 Views)
A few generic comments for your VI:
  • If you want the elements in order, you don't need to wire the indices of "index array". Saves lots of time and avoids mistakes! (See also)
  • If you "bundle" into a cluster for the chart instead of building a 1D array, you don't need the conversion to 2D array.
  • If you use the correct mechanical action for the "start button", you would not need the value property.
  • There is never any need for greedy loops.
  • I would recommend a state machine architecture instead. Currently it's a one-shot deal, burning 100% of a CPU core waiting, then rolling down the hill until finished. Seems boring 😉
  • There actually is a +1 primitive.
(5,643 Views)
Thanks for your reply,
  1. Got rid of the indices
  2. Im going to leave it as an array because im now writing it to excel
  3. Is switch when pressed not the correct action?
  4. Ive just read your greedy loops bit, is the solution to just as a wait in?
  5. I agree, dont think im at that stage yet tho, just trying to get it working first 😉
  6. What about +1?
Cheers
(5,619 Views)
Typically the correct action is "latch when released". This way the button is normally OFF and when pressed will remain TRUE until is is read by the code, at which time it will automatically return to FALSE. (No way for the code to miss it as e.g. with "switch until released" and no need to reset it as e.g. with "switch when pressed")
Yes, that's the "bandaid" solution. A proper state machine is preferred. A greedy loop spins many millions of times per second, consuming 100% of a CPU core, draining your battery, stressing the thermal management of the CPU, and starving all other processes running. Even a 1ms wait would reduce the CPU use to a tiny fraction of a %. Typically you make it longer, e.g. 50ms.
@newman3108 wrote:
6. What about +1?
(5,595 Views)
