Stop a sub VI from main VI
Sorry I could not understand from your images. But where are you updating the value of string control??
Labview user
Message 21 of 41
(2,566 Views)
When I receive the message OF0 via tcp (it arrives!), the case structures write the string "Spegni" and the value should change, because the default is null.
Message 22 of 41
(2,564 Views)
By looking at your SubVi I found that in your sub vi event structure you have Stop2 boolean. when it is pressed it stops your SubVI. there you are also reading new value. In this event structure new value will be the value of Boolean Stop 2. You have to add another event case with Value(signaling) of string control string or Value to stop your Sub vi.
Labview user
Message 23 of 41
(2,561 Views)
I have this event... case 2.
I attach all my program... I think is better than screenshot!
Message 24 of 41
(2,559 Views)
Accepted by Skeggy88
Here I have tried to attach a solution. It could not be the best but can help you. What I think the problem was that once you have connected a while loop for your subvi it can not take updated values from main vi. What I did was used multiple loops for controling a subvi. Hope it solves your problem.
In the main vi there are three buttons to Open a subvi close the subvi and close main program.
Labview user
Message 25 of 41
(2,556 Views)
It works!! Thanks to all for your help!!!!
Message 26 of 41
(2,551 Views)
Passing in a control ref from the main VI to the subVI is more robust than writing to a global on the outside and reading it on the inside.
  Less potential for race conditions.
Bill
CLD
(Mid-Level minion.)
Message 27 of 41
(2,536 Views)
could you give simple exaple. It will be really helpful.
Labview user
Message 28 of 41
(2,505 Views)
Here is a very quick demo of reading and writing a main VI's controls by passing references to a subVI.
From a reference, read/write the Value using a Property Node
Certified LabVIEW Developer
Message 29 of 41
(2,497 Views)
How does a reference minimize the chance for race conditions? The answer is it doesn't. You can still have race conditions because a control reference will allow access to the same control from two places at the same time.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 30 of 41
(2,482 Views)
