Stepped Limit Lines
Alright that was dumb on my part. I have the delimiter set for a semi colon (;). Now my issues is that it does read the decimal point for my decimal values. Ive tried a couple things, and I either get the number without the decimal point (ex: .34 comes outs as 34) or I get this (ex: 1.15 comes out as 1, cutting out the values behind the decimal point). Ive looked into using fract/exp string to number function, but I am unsure as to how to incorpate that into what im doing.
Message 11 of 15
(2,218 Views)
Accepted by topic author Zzimmha42
Is this what you want?
The attached VI uses the suggestions which have been posted along with a few modifications I added to implement this.
Lynn
Message 12 of 15
(2,211 Views)
Johnsold,
You literally are the man. This is exactly what I was going for thank you!
Message 13 of 15
(2,199 Views)
Hi zz,
On your conversion problem: not only the delimiter is important, the format string is important too!
Again: read the help for that function including the links in the help!
Message 14 of 15
(2,188 Views)
These things are not difficult. As GerdW recommended, please read the detailed help for the functions used so that you understand how it works.  All the details are important.
Lynn
Message 15 of 15
(2,174 Views)
