Step up and step down Voltage
I'm using the NI 9263 to apply 2.5V in a sample and after 120 seconds I need to apply 0V. I need this process to repeat itself endlessly, until I want to stop.
For example: 0V --> 120s --> 2,5V --> 120s --> 0V --> 120s --> .....
How should I do this?
(2,532 Views)
Accepted by matheus08
Hi Matheus,
a little state machine with 3 states: switch on, switch off and wait comes to mind.
What have you tried so far?
Also: Is this a windows application or are you on RT?
Remember Cunningham's Law
(2,511 Views)
Hi matheus,
after taking the free training resources offered in the header in the LabVIEW forum you should be able to come up with this:
What have you done so far?
(2,504 Views)
@GerdW wrote:
I give you kudos for this but in no way does my kudo reflect how valuable your contribution is. (ref) Smiley Very Happy
aputman
Heads up! NI has moved LabVIEW to a mandatory SaaS subscription policy, along with a big price increase. Make your voice heard.
(2,496 Views)
Hi Peter,
Tou are right. A state machine solved my problem. However, I used a machine with 2 states.
Thank you.
(2,452 Views)
Hi GerdW.
I have used a state machine with 2 stages and solved my problem. However, your solution is also valid.
Thank you.
(2,448 Views)
