Static arrays
IMO, it's not really ready for prime time.  BUT, I also know that this is the future of LabVIEW, so we have to try to shape its destiny right now.  That is why I am trying to use it, at least at home, to get used to it.
Bill
CLD
(Mid-Level minion.)
Message 21 of 26
(1,546 Views)
Accepted by topic author andrewDJ
HI
I checked in NXG 5 and the make current value default also works on complete arrays with different values.
If you either select the outer border or (if visible) the index you can select make current value default and it will not change the values in the array anymore. So acting exactly as in current gen LabVIEW.
greetings from the Netherlands
Message 22 of 26
(1,536 Views)
I misunderstood what you meant originally Albert, sorry.
Now I've got it: drop an empty array onto the Panel, size it with the number of elements I need, enter values for those elements, when done right-click the array and select "Make current values default", save, exit NXG, restart NXG and it has remembered the values.
This answers my original query and gives me a static query, so thanks for persevering!
Message 23 of 26
(1,531 Views)
I did mention that a few messages ago, but called it an "ugly idea", even though I didn't detail just how to do it.  I think i deserve at least kudos.  😉
Bill
CLD
(Mid-Level minion.)
Message 24 of 26
(1,514 Views)
Was that that what you were saying??  🙂  I didn't get it then either: I hadn't made the connection between entering values AND THEN setting array to default until the later clarification.
You deserve kudos for coming up with a better solution for my problem though.
Message 25 of 26
(1,508 Views)
I'm actually just glad you have a solution that works.  🙂
Bill
CLD
(Mid-Level minion.)
Message 26 of 26
(1,505 Views)
