Statechart module: crashes when I want to save state
I am using the LV Statechart Module (version 8.6.0). LabVIEW crashes when I want to save a state (by clicking "OK" on the state dialog). The crash does only occur if I have some member VIs of a quite large class hierarchy in the state. It does not occur if I for example just wire through the simple error cluster that is part of my state data cluster.
Does anyone have an idea how I could avoid this problem?
The LabVIEW failure log file is attached.
Thanks in advance for any hint.
(3,604 Views)
Looking at this quickly, I do not know the core root cause, but I am guessing that you could work around it by putting your guard or action code into a subVI and using that subVI instead of placing the code directly in the guard/action. Something appears to be going wrong as we try to commit the guard/action VI you created for the state - I am guessing there is a bug in this process as it encounters some of the class stuff you are using, and using a subVI to wrap it will avoid this.
Any chance you can provide the files needed to reproduce this (either here or privately if you prefer). The stack tells me a little bit but we'll have a much better chance of resolving this fully in a future release if we can reproduce it here.
Nick
(3,593 Views)
Hi Nick
Thanks for your reply. I will try this.
Can you give me your email address (either here or by writing to langer@hifo.uzh.ch if you prefer)? I can then give you access to the site where you can download the full source code.
Dominik
(3,576 Views)
Update on the issue:
I tried to put the state code into a sub VI. The state dialog can now be closed without crash, but a crash occurs during compiling the statechart. After restarting, LabVIEW does not show the dialog asking to investigate the internal error (which would allow creating the failure log file).
I will now go through all states/transitions of the statechart and replace any code by enclosing subVIs. Hope that helps...
(3,570 Views)
The sub-VI approach also does not help. Again, as soon as the a subVI contains my class stuff, LabVIEW crashes when the state dialog is closed...
The failure log file contains the same lines as without sub-VI approach:
c:\builds\penguin\labview\branches\Saturn\dev\source\diagram\CopyAccumulator.cpp(36) : DWarn: CopyAccumulator is being destructed without being flushed.
$Id: //labview/branches/Saturn/dev/source/diagram/CopyAccumulator.cpp#1 $
(3,563 Views)
Thanks for the updates; I'm sorry the workaround ideas have not proven effective. I will contact you via email to get info about getting the files and do some investigation.
Nick
(3,553 Views)
Accepted by dlanger
The problem does not occur anymore in LabVIEW 2009.
(3,473 Views)
