State machine won't stop
I am using a state machine to increase temperature by changing resistance. I am using labview 8 and the libraries for the controller I'm using won't work so I am writing the commands. Each different state sets a different temperature. In the last state I have a stop if true button but when I run my program it doesn't stop after the last case. I have attached my program. Sorry about how messy and unorganised it is. I have been trying different ways to fix it and it's a bit all over the place.
Thanks.
Message 1 of 24
(3,958 Views)
Do you know if it even gets to state 20?
Bill
CLD
(Mid-Level minion.)
Message 2 of 24
(3,955 Views)
Yeah it goes through all the states doing exactly what it's supposed to but after state 20 it returns to state 0.
Message 3 of 24
(3,944 Views)
Returns to state 0 and repeats the process I should have said
Message 4 of 24
(3,934 Views)
I dunno - works for me.
How did you confirm that it did go to 20 and start over?
Bill
CLD
(Mid-Level minion.)
Message 5 of 24
(3,928 Views)
Oh it worked for you? That's strange. I used highlight executuion and then I'm saving to a spreadsheet each iteration so there should just be 8 files but it just kept on running for me today. Is the way I am using the shift registers correct? (new to labview) I have a previous version where I hadn't started using them yet and it still works.
Message 6 of 24
(3,924 Views)
I know what your problem is.  The way you have it set up, every iteration between 6 and 20 will use the "0, default" case, making it do more reports than you were expecting.  Because you had so many long waits, you probably thought it was repeating itself.  To avoid this, make an empty case for that range.
Don't forget to wire the empty case wires all the way through..
Bill
CLD
(Mid-Level minion.)
Message 7 of 24
(3,916 Views)
Oh I see. So could I delete case 20 and make a case 7?
Message 8 of 24
(3,906 Views)
Accepted by topic author pagz
Well, don't delete it.  Just rename it to 7.  🙂
Bill
CLD
(Mid-Level minion.)
Message 9 of 24
(3,903 Views)
Hey, it's NOT BAD for a new LabVIEW programmer.  If you could look around the NI Site and do some of the tutorials, you will see how to clean up your code and learn best practices.  🙂
Bill
CLD
(Mid-Level minion.)
Message 10 of 24
(3,897 Views)
