State data conduit - a good idea?
If you're using a state machine, you've got state data that you pass to successive iterations. The typical approach is to cluster together like terms, then pass them through shift registers. Generally, the amount of state data is proportional to the complexity of the program, and inversely proportional to the neatness of your diagram.
I would like to hear some feedback on the following approach: creating a top level cluster and calling it our state data conduit, which is simply a container for all the shift register data.
State Data Conduit
One advantage with this approach is it offers much neater calculations. A typical calculation may include a constant, some volatile data, and some non-volatile data. I have defined volatile data that stays in memory only as long as the VI stays in memory, and nonvolatile data that is written to disk once the VI is exited, then repopulated on the next call of the VI. Also, you can store references nicer as well, especially references that may dynamically change, such as ones used for dynamic event registration. Finally, for states that don't access certain clusters, there is no need to wire a short all the way across the case for each shift register on individual state clusters.
Can someone provide some disadvantages for this approach, or offer comments?
Jack
Message Edited by mechelecengr on 10-16-2008 02:51 PM
Message Edited by mechelecengr on 10-16-2008 02:54 PM
(3,748 Views)
Just to give you an idea, this is an example of what I am trying to avoid with all the shift registers:
Lots Of Shift Registers
Message Edited by mechelecengr on 10-16-2008 03:03 PM
(3,744 Views)
Many people use this construct and I certainly find it better.
The only real problem you might have with it is if you have very large data arrays in there and you want to avoid memory copies.
___________________
Try to take over the world!
(3,737 Views)
I agree with tst.
I often have  an "Indicators and Flags" cluster, usually a typedef, and separate shift registers or Action Engines for arrays with large amounts of data.
Lynn
(3,731 Views)
tst brings up the most obvious flaw that I noticed as well. If you change just one piece of data in any one of the clusters and bundle it up, LabVIEW creates a copy of all data in the conduit. So, assuming you're only taking a negligible hit on memory, are there any other disadvantages?
(3,727 Views)
Not necessarily. Ideally, LabVIEW will reuse the buffer even in this case, but since it might create a copy of the cluster at any point in time, keeping large data separately is sometimes a good idea.
Another flaw is that unbundling the names takes up some screen real estate, especially if you use descriptive names, but I think it's a trade-off worth making as the alternative isn't any better.
___________________
(3,709 Views)
