LabVIEW Implementation of VXI-11 Discovery Protocol
Has anyone implemented the VXI-11 discovery protocol using LabVIEW? I know I can use MAX to detect LXI instruments, but I like my code to be able to perform inventory functions independent of MAX. Is there a way to call the discovery routine within MAX from LabVIEW?
Chris
Practical Physics, LLC
www.practicalphysicsllc.com
(3,983 Views)
Chris,
VISA 4.4.1 supports automatic detection of LXI devices that support the mDNS technologies.  If you have this version of VISA installed, you should be able to use the "VISA Find Resources" node in LabVIEW to find LXI devices.
Song Du
Systems Software
National Instruments R&D
(3,980 Views)
I tried using TCPIP?*INSTR as my search string, but it doesn't find anything that I haven't defined as a VISA TCPIP resource in MAX.
Chris
(3,974 Views)
Hello Chris,
If the device is not registered in MAX, then it will not show up using this method. However, if you know the IP address of the instrument, then you can add it manually. There is no way to have MAX scan for instruments programmatically. Here is a tutorial on LXI.
Thank you,
Ryan
(3,934 Views)
