 Hummer1
			Hummer1
			02-05-2010 10:16 AM
Thank you!!!!!
For the past several months I have struggled to learn how to use LabView, at all...much less effectively. With the help of the forum I finally was able to cobble together a display manager for our lab. It was slow, unresponsive and completely event driven, and totally unmaintainable. With the help of several key forum members (and I'm sure the good wishes of the rest) I learned about state machines, queues and other good habits.
In less than 2 days, I have rewritten the project in state machine form and it works beautifully. It uses a typedef enum for state definitions and a sub.vi for variable initialization. The BD is readable, simple and can be seen on one screen (nearly...have to scroll down a bit to see all of the error function.)
I can't thank all of you enough.
Hummer 1
 Mark_Yedinak
			Mark_Yedinak
			02-05-2010 10:23 AM
 Darin.K
			Darin.K
			02-05-2010 01:00 PM
Now young Grasshopper it is time to take it to the next level.  With LV scripting you can write a state machine to write your state machine for you.
I need coffee now, still waiting for a state machine to do that. Wait, I, err my daughter, got a Mindstorm for Christmas, could their power be unleashed in the physical world?
02-05-2010 01:02 PM
Oh thank you master, but I see the coin is still in your hand.
Hummer1
 NIquist
			NIquist
			02-05-2010 01:08 PM
A Coin!  Sheesh, back in my day all I got was a pebble.
Congrats on your success!
 Taylor.Kendall
			Taylor.Kendall
			02-05-2010 01:10 PM
We have used State Machines for years and they are great. But the thing thats even better is a state machine with a queue in front. You can execute the same state multiple times if need be and you can use different states in different orders depending on what is needed.
Give it a shot for your next project.
 PaulG.
			PaulG.
			02-05-2010 02:41 PM
A queue-driven state machine is my favorite architecture. And I use a typedef enum as the data type for the states. You can mix and match states and it's so easy to maintain and read.
tsksesa wrote:We have used State Machines for years and they are great. But the thing thats even better is a state machine with a queue in front. You can execute the same state multiple times if need be and you can use different states in different orders depending on what is needed.
 Mark_Yedinak
			Mark_Yedinak
			02-05-2010 02:52 PM
PaulG. wrote:A queue-driven state machine is my favorite architecture. And I use a typedef enum as the data type for the states. You can mix and match states and it's so easy to maintain and read.
I also use the queued state machine extensively. Recently Ihave switched to using a cluster for the state rather than a simple typdefed ENUM. My cluster consists of the typedefed ENUM and a variant. This provides a mechanism for easily passing data between states and since it is a variant one the poster and the specific state need to know the data type. New states can be added without worrying about updating typedefs for the state data that may be required.
 DianeS
			DianeS
			02-07-2010 01:12 PM
A queued state machine is your friend
It's not just a fad or a trend
A typedef'd enum
Leaves plenty of room
For changes you won't have to mend!
I also like type-defined clusters
A variant gives it some lustre
You can pass anything
Array, number, or string
And your next state will always pass muster!
d
 NIquist
			NIquist
			02-08-2010 08:45 AM
