State Machine...
Ok, I've posted the 8.6 version
Message 11 of 24
(2,430 Views)
There is no code in the zip file.  There's a file without an extension...
Message 12 of 24
(2,424 Views)
Ok, I renamed the file to have a VI extension and it opened.
As I stated before, store you data in shift registers.  Be sure to pass them through each case they are not altered in.
Message 13 of 24
(2,418 Views)
Ok great!!! can u help me out please
Message 14 of 24
(2,402 Views)
can you help me out plz!!
Message 15 of 24
(2,395 Views)
I suggest that you open the LabVIEW help and search for shift register. At this point you ar easking for assistance with the most basic elements of the langauge. You can also go through the online tutorials. We are more than welcome to help you but you do need to take some time to become familiar with the basics of the language.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 16 of 24
(2,385 Views)
I know about Shift Registers, but I jus don't understand where you're telling me to add them in my program. Please bare with me I'm trying my best to learn
Message 17 of 24
(2,381 Views)
Your state machine consists of a while loop with a case structure inside of it. Place a shift register on the while loop for any data you want to pass from state to state. Wire this data through the case structure and make sure that it is passed through all the cases. Here is an an example.
Mark Yedinak
LabVIEW Champion
Message 18 of 24
(2,374 Views)
I don't have it done like this , but the info is still being passed on. I'm just not able get a hold of the values in the voltage data so I can calculate the average voltage because for the DAQ assistant it is set to 1 sample (ON DEMAND)
Message 19 of 24
(2,371 Views)
If you aren't following our advice, what are you doing then?  How is the data being passed on?  As always, show some code.
Message 20 of 24
(2,339 Views)
