State Machine...
Hi Friends....I need you help again 🙂
I'm asked to build a state machine that acquires analog inputs – voltage on channel 0 of a simulated DAQ device (PCI-6251).
I've listed each state and its description below.....
State                                          Description
Idle, Default                                 No data acquisition. Remains idle
                                                  state = idle, next state = start
Start                                           When a start button is pressed on front panel
                                                  state = start, next state = acquire
Acquire                                       Acquire voltage data (N samples) through analog input channel 0 of a simulated DAQ device (use DAQ assistant).
                                                  Single-ended measurement.
                                                  state = acquire, next state = display
Display                                       The voltage data is displayed on a chart. The average voltage (last three values) is also displayed on the same chart
                                                  state = display, next state = log
Log                                             Data acquired is written to a measurement file (.lvm), in the append mode
                                                  state = log, next state = stop (if stop button is pressed), or acquire (if stop is not pressed)
Stop                                           When the stop button on front panel is pressed. The program stops and displays how many seconds have elapsed
                                                  since start button was pressed – example: “Data acquired for 68 seconds”
My program is working upto the part of aquiring the voltage data and displaying them on a chart.
MY QUESTIONS are:
1)  From where can I access the voltage data so, I can get the last 3 values and calculate the average voltage and display
     them on the same chart? (Display State)
2)  Is there any connections or settings involved for the measurement file (.lvm) for the voltage data to be written into the file? (Log State)
3)  How can I access that measurement file as a spreadsheet or something? (Log State)
4)  How do I keep track of the elasped time? (Stop State)
I've attached below...its version 12 of LABView.
Thanks in advance!
Message 1 of 24
(5,045 Views)
The project does not contain any code...
Keep your data in shift registers.
Message 2 of 24
(5,028 Views)
I'm not able to use the DAQ assistant from version 12...I don't know why?? Could you help me out that please
Message 3 of 24
(5,024 Views)
Did you install DAQmx AFTER installing LabVIEW 2012?
Message 4 of 24
(5,016 Views)
yes... i even have Measurement and Automation Explorer
Message 5 of 24
(5,011 Views)
please anybody help me out...
Message 6 of 24
(4,994 Views)
please help me! I really need your help guys...
Message 7 of 24
(4,977 Views)
Try reattaching your state machine code, but first down-convert it to 8.x.  You will get more responses if more people can view your code.
Reese, (former CLAD, future CLD)
Some people call me the Space Cowboy!
Some call me the gangster of love.
Some people call me MoReese!
...I'm right here baby, right here, right here, right here at home
Message 8 of 24
(4,971 Views)
He would get more responses if he actually POSTED his code. A project file doesn't help without the code.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 9 of 24
(4,964 Views)
This is true.  He was told already he needed to post it.
Message 10 of 24
(4,958 Views)
