Online shopping is currently unavailable.
Please contact us for help or try again later.
04-22-2013 11:20 AM
**Updated code with error handling wired.**
04-22-2013 01:03 PM - edited 04-22-2013 01:13 PM
I've cleaned up your VI...please take notice the difference, this is a CLD graded requirement
04-22-2013 01:57 PM - edited 04-22-2013 02:04 PM
Apok,
Thank you for the tips and I will handle the code accordingly in the future. I am noticing an odd response from the analog inputs. AI0 seems to be not reading correctly. If I turn off any two digital lines, the corresponding analog input reads correct. In the case of two or three, I get incorrect readings as if the digital lines are not high at all. I have retested the hardware with a simple program I wrote previously and know there is no issue with my electronics. Any ideas? I'm thinking the output of the daq read vi is not in a format I understand. I assume it is double format, 2D array where each row is an individual analog input channel.
04-22-2013 02:19 PM - edited 04-22-2013 02:31 PM
you are correct...
I've checked on my end here and it seems to be working, check your connections to it making sure everything is tied down and tight....
04-22-2013 03:30 PM
Ok, the analog inputs needed to be configured single ended. Attached updated code. What I need to do now is pick of the data points for each of the three channels at 1 second and 20 seconds. Take the difference and run those 3 resultant deltas through some logic to drive the LED's. I guess I can do this operation on the entire 2D array outside the state machine?
04-22-2013 03:45 PM
I also noticed the waveform chart keeps overwriting the previous samples so I only get one sample displayed at a time. Why is this?
04-22-2013 03:57 PM
yes, you can...i modded your vi graph, check your channel assignments....
04-22-2013 05:02 PM
Apok,
Ok here is my updated code. I removed the waveform chart. I only need it to view the data trend over the 20 second sample period and is not necessary for the end product. Likewise with the table but I need to keep it on the front panel for now to make sure I am extracting the correct samples. I modified the while loop wait constant to 1000 ms as before I was getting 50e-3 X 20 samples in the output array. I put two more double indicators on the front panel to see what the 20th and 2nd sample are after the 'read' state is complete. I am not getting any values from the array. The cascaded 'array index' vi's are used to pull the samples I need. Am I missing something here? Thank you again for your assistance.
04-23-2013 09:22 AM
Apok,
Here is my proposed solution. I cannot get the first sample to return true. The 20th is reading out fine but my logic may be incorrect. I am implementing the first-call vi to accomplish this. I just need the first (or second sample is fine also) sample to provide the delta calculation. Thoughts?
04-23-2013 09:40 AM
remember and becareful......
First Call? returns TRUE the first time the VI runs after the first top-level caller starts running, such as when the Run button is clicked or the Run VI method executes. If a second top-level caller calls the VI while the first top-level caller is still running, First Call? does not return TRUE a second time.
did you try the last mod from me?
