Standard output on system exec VI
@ag9 wrote:
The concatenate returns the expected output.
Then I'd suggest giving kudos and marking a solution.
@ag9 wrote:
That is what confuses me.It works on the cmd but does not do on system exec.
It works in both, and I stated why one output is sometimes returned rather than another.  It is the result of the function you are running.  When you have a command prompt, both the standard output, and error output are concatenated into a single output.  When you run the function using LabVIEW you get both outputs, and it is up to you if you want one, or the other, or to concatenate both like the command prompt does.  This does not appear to be a compatibility issue, but just how things work.
Message 11 of 12
(1,709 Views)
Can you please assist me with this issue I am having. I cant seem to see a STD OUTPUT and need it to end run program correctly.
Message 12 of 12
(907 Views)
