Stacking images in array.
i tried to convert images to panorama without overlap from array.In panorama.vi , i have attempted it. But I don't know how to automatically do it.
In join images.vi, I added for loop to automate it. But I cannot automate offset for X and Y axis for draw patterened pixmap.
Message 11 of 20
(2,348 Views)
Not duplicate per se, but you might want to mention this post, as it is related.
So there you wanted the images in a 2D array, now you want to stitch them together?
Message 12 of 20
(2,346 Views)
Accepted by topic author SSG0484
OK, so I left out a few steps, but after marking my suggestion of how to use ImagetoImage, you abandoned the IMAQ functions and returned to the Picture functions!
One step I overlooked is that your first loop (creating the sub-images) doesn't process all the Images, just a row.  Better to process them all (with nested For Loops, create a single Stitched Image, then take the 2D array of sub-Images and (using the algorithm I suggested) stitch the 2D array of sub-Images together to get this:
To create this, I started with your original IMAQ code and created two nested For Loops, that created the 2D array of sub-Images, along with a 2D array of X Resolutions and a 1D Array of Y Resolutions, then created a single Stitched Image whose size was set by summing one row of X Resolutions and summing Y Resolution, then a second nested For Loops that placed each of the sub-Images into the single Stitched Image using the IMAQ logic I posted earlier (and that you marked as a Solution).
Let me know if you want me to post my revised code, or whether you want to "learn" by modifying your own code as I've outlined above.  [It helps to know that there really is a working solution, as evidenced by the above image ...].
Message 13 of 20
(2,348 Views)
Can you post the labview code.
I tried a lot with IMAQ functions and fed up of that and after that only I give a try on picture functions.
Message 14 of 20
(2,342 Views)
I now want images as stitched.
This is my second task.
My first task was to arrange images in an array.
Message 15 of 20
(2,327 Views)
Here you go.  I'm attaching it as a LabVIEW Snippet to allow anyone with Vision to replicate it.
Revised StitchRevised Stitch
Message 16 of 20
(2,326 Views)
Which function you have used as input to summer in case of X resolution?
Is it array subset function.
Message 17 of 20
(2,315 Views)
SSG0484, as you do have the vision toolkit, you don't have to bother with the picture toolkit method.
Kudos to Bob for
https://forums.ni.com/t5/LabVIEW/Stacking-images-in-array/m-p/3933681#M1117940
in response to:
https://forums.ni.com/t5/LabVIEW/Stacking-images-in-array/m-p/3933537#M1117900
indeed, it is significantly harder to stitch those indvidual images together,
than using the reshape-array.vi to spawn an 2d array of those individual images
attached as LabView 2010
does there exists a more elegant solution?
Message 18 of 20
(2,304 Views)
No.  It is possibly the most commonly-used Array function (you might not recognize it because it changes its appearance slightly if you wire a 2D Array into it ...).  Create a 2D Array and try wiring it into some "common" Array functions to figure it out for yourself ...  (Hint -- look at the output, then think).
Message 19 of 20
(2,299 Views)
Thanks for the support. Best regards, Susan
Message 20 of 20
(2,283 Views)
