Stacking Plots
I'm trying to plot five data points in a waveform graph. I need to stack plots such that two data points appear in one plot and three in the other. Please see the simple program attached. Any help you can provide will be greatly appreciated.
Message 1 of 9
(1,350 Views)
Hi GRC,
attaching your VI downconverted for an older LabVIEW version will help you to reach a broader audience.
Most say "LV2021 or older", I prefer LV2019…
Message 2 of 9
(1,312 Views)
If you know which measurements to plot on each plot area, you could create a separate chart for each set of signals:
I turned off the 'stack charts' option above to allow for the grouping (Plots 1,2; Plots 3,4,5) in your post.
Doug
Enthusiast for LabVIEW, DAQmx, and Sound and Vibration
Message 3 of 9
(1,255 Views)
Thanks for your reply. I know I can use individual charts and you can also put all the data points in one chart and stack them, but I was trying group them first (into arrays or clusters) and then stack them. Any thoughts?
Message 4 of 9
(1,252 Views)
I don't know how to do that with a chart in LabVIEW.
You could implement the chart update behaviors with a Mixed Signal Graph (MSG). The mixed signal graph allows you to specify which signals are assigned to which plot areas, but I don't recommend MSG as it can be finnicky.
In your application, is the number of signals fixed? the number of charts?
If the number of signals is variable, but the number of charts is fixed, I would place a graph for each chart, buffer the data to create the chart update effect, and send an array of buffered signals to each graph.
Doug
Message 5 of 9
(1,244 Views)
It is not clear what you want to achieve. Can you make a sketch?
Message 6 of 9
(1,131 Views)
nevermind
Message 7 of 9
(1,129 Views)
Why not just use a cluster of two charts?
Message 8 of 9
(1,087 Views)
I'm not sure what you mean by "Stack them".  I can think of two scenarios:
  1. Create Upper Chart and Lower Chart (two separate Charts).  Make them the same width and same X scaling, and align them so that Upper is right above Lower.  Create separate plots for the two Charts.
  2. Plot a single chart, but have two "Y" axes, the one on the Left where you plot, say, Channels 1, 2, and 4, and the one on the Right where you plot Channels 3 and 5.
Option 1 has already been suggested, but I gather isn't what you mean.  Option 2 actually exists for LabVIEW Charts and Graphs.  However, it can be very tricky to implement!  I actually tried to do this for plotting a Waveform Graph showing 7 channels of Flow rates (units liters/min) and one of Coolant Temperature (°/sec), but eventually gave up and created two graphs (Option 1, above).
Message 9 of 9
(939 Views)
