Stacked Bar Plots in Mixed Signal Graph
Is there a way to have a stacked bar plot compiled and displayed in the mixed signal graph indicator from multiple plots as inputs?
Message 1 of 9
(4,065 Views)
This is Doug from applications engineering at National Instruments. I've attached a screenshot of a mixed signal graph with a stacked bar graph. Please let me know if this was what you were looking for. If you have any other questions, let me know. Thanks
Doug W
Message 2 of 9
(4,033 Views)
Doug,  Thanks but I need to do it programmatically, thus specifying the properties to do this.  Do you have an example of how to stack y values from a 2D array for multple series with properties shown?
Message 3 of 9
(4,000 Views)
Here is mydata and a mixed sig graph.  I just want to stack the bars when a 1 occurs in the data.  the array is a 2d one that has the series in rows and the time events for the x axis in the columns
Message 4 of 9
(3,996 Views)
Something like this?
Message 5 of 9
(3,985 Views)
I think we are getting closer but I do not see what I would expect in a stacked bar graph in excel.  Please take a look at the data in the array in column 525.  It has more than just qty 2 of the value 1 in many of its cells.  Hence I would expect to see a spike greater than 2 which is what I see on the chart that you provided.  I did the task in excel and it was easy to do and have attached it for your reference.   It is the same data that I provided above in the prior vi.
Message 6 of 9
(3,979 Views)
Oh, oops. I thought this was a property issue, not a math one. Doesn't excuse my math, though 🙂
How about this:
Message 7 of 9
(3,967 Views)
Doug,
I am trying to create a stacked bar graph like the one in your post.  Could you please send me the code to do that?
Steve D.
Steve Drouilhet
Message 8 of 9
(3,712 Views)
Hi Steve,
Since this post is from 3 years ago, I do not think that Doug is monitoring this anymore and likely does not have the code saved. You are welcome to create a new post, which might get more traffic.
Maggie M.
Application Engineer
http://www.ni.com/support
Message 9 of 9
(3,702 Views)
