Square Wave Generator ( FPGA )
Hello.
I'm using the NI FlexRio PXIe 7962R.I should generate a square wave output from fpga.I created  an adapter module socket. I created the socket clips and everything is working. I used the Square Wave Generator in the single-cycle while loop. However, sending him running and testing the output signal with the oscilloscope , I see that a square wave is generated non-regular. Below the 2.857 MHz the displayed frequency oscilloscope is regular, but by settting a frequency above the frequency that 2 MHz visualize the oscilloscope is always 2.857 MHZ and in addition a signal gitter lot.
As parameters in the square wave generator I used:
Output:Boolean
Fpga clock Rate: 64 MHz
Execution Mode: Inside single-cycle timed loop
How can I resolve it?
Place the image of my vi.
Thanks.
(2,877 Views)
Hello Brugiando,
I am afraid I did non understand the issue that you are facing.
When the frequency of your signal is more than 2.8MHz you can not see it properly in the oscilloscope?
Antonios
(2,831 Views)
