Splitting an array
      I have an array (1d) with 178 double values, Each value has an indicator in the front panel. I wanted to know how to split the array and send 178 values to 178 indicators  present in front panel. Are tabels useful in these case?
Message 1 of 8
(4,125 Views)
Tables are very useful in this situation.  I really hope you don't have 178 numeric indicators on your front panel.  That would be one crowded panel.
Message 2 of 8
(4,110 Views)
I agree with crossrulz,
I hope you do not have 178 numeric indicators on your front panel.  Yikes!  😮
A table definitely makes sense.  Everything must (and can) fit within a single screen.
Message 3 of 8
(4,102 Views)
Even an array indicator would be preferable to maintaining 178 indicators but,  IF you MUST something like this would get you there with enough wires.
Silly Snippett tool.  those ref controls should be control refs.
"Should be" isn't "Is" -Jay
Message 4 of 8
(4,098 Views)
Jeff·Þ·Bohrer wrote:Silly Snippett tool.  those ref controls should be control refs.
Code Capture Tool is far superior than the built in snippet tool.  It's also available via VIPM on the LV Tools Network.
Message 5 of 8
(4,095 Views)
I know.  I even have it installed I should just re-target that old menu shortcut with my own QDSC but I'm just a bit lazy about that.
Message 6 of 8
(4,079 Views)
    R there any detailed examples wrt my situation. If so pls post it
Message 7 of 8
(4,039 Views)
If you have 178 numeric indicators, simply use "index array", expand it for 178 outpus, and wire the terminals in sequence.
Can you show us a picture of your front panel?
Message 8 of 8
(4,010 Views)
