Spliting text
Why don't you post whatever VI you have so far?Smiley Wink
It is a lot easier for people to review your VI and suggest fixes, then it is for people to code up a program for you from scratch!
Message 21 of 33
(2,263 Views)
Hi jeyanthi,
see the attachment. It's only one solution, maybe it helps.
Mike
Message 22 of 33
(2,239 Views)
hi Mike
Can i have the example in labview 8.0 ..plz thank you
Message 23 of 33
(2,230 Views)
Hi jeyanthi,
here we go.
Mike
Message 24 of 33
(2,226 Views)
Thanks Mike it works. I need another help..
0.5 1090120 2355
1.0 1090121 0000
0.5 1090121 0010
1.0 1090121 0100
0.5 1090121 1200
1.0 1090122 2005
0.5 1090122 2010
1.5 1090125 2140
2.0 1090125 2145
1.5 1090125 2150
Above data is the result data i get ..now how to do this
if the data is
1.0 1090121 0100
0.5 1090121 1200
The result should be recorded in every 5min as below:
1.0 1090121 0100
0    1090121 0105
0    1090121 0110
0    1090121 0115
0    1090121 0120
0    1090121 0125
0.5 1090121 1200
And if the data is like this...Miss some dates of data
0.5 1090122 2010
1.5 1090125 2140
the output must be in:
0.5 1090122 2010
0    1090123 0000
0    1090124 0000
1.5 1090125 2140
How to do this .. need help
Message 25 of 33
(2,187 Views)
Hi jeyanthi,
It sounds to me like you could use some instruction. You might want to consider taking a LabVIEW class (maybe Basics I and II?).
As for your specific question, you just need to architect your program to put in all the in between five minute blank chunks of data when it finds a gap. For instance, you could subtract timestamps to find out the time between then write in the between bits before writing the current reading.
Jeff | LabVIEW Software Engineer
Message 26 of 33
(2,141 Views)
Hi
 Thank you, can i get a small example plz...
Attending the class would be a great idea have told my management abt it..but need to pay erm have to ask my  boss first
Message 27 of 33
(2,127 Views)
hi i able to insert the 0 for the days not rain .. im only confuse inserting 0 data to every 5 min gap
Message 28 of 33
(2,113 Views)
Jeyanthi,
Try this type of thing out. You may want to do the same type of thing in both false cases for incrementing.
Vince M
Message 29 of 33
(2,062 Views)
Hi
 Thanks ..but i didnt receive any output all i get is empty array at the end cos my quotion and reminder function returns 0 value....
Erm.. need more guide
Message 30 of 33
(2,049 Views)
