strange waveform update problem:Urgent!!
I got a very strange problem with my waveform chart display, it can only display 2 plots on one waveform chart. I need to display 4 plots on one waveform chart at the same time, please give me some good ideas how to do this. The waveform chart reference is used. My program has been attached, please run it to see the problem, only zeros are displayed, if you only connect two data, the display is correct (you need to change subvi). LabVIEW8.5 is required.
(3,331 Views)
Find the VIs
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
(3,320 Views)
problem solved?
Balaji PK (CLA)
(3,278 Views)
