Split the information within each element of an array in LabVIEW
Hello
Thank you for your support.
Actually I have done the code (you can see in attach) but I don't get the results.
In the end I need to have 2 arrays. One with the time data and one with the amplitude data. (see the block diagram), I have written the label above the string.
Can you please have a look.
Best Regards,
Yljon
Message 11 of 15
(1,141 Views)
Hello Caria
 Have you got my reply of the result ?
Regards
Message 12 of 15
(1,132 Views)
Accepted by topic author yljon
Almost there.
The replacement string of the Search and Replace Array should be "$1".
$1 means the strings matching the reg.ex.'s first capturing group ( "\\A" (begin of string), "\n" or "\s") is used as a replacement. So \n\s\s\s is replaced with "\n", "\s\s\s\s" is replaced by \s, ",\s\s\" is replaced by "\s".
Message 13 of 15
(1,131 Views)
Hello
Yes, Right it worked.
I thank you a lot.
Where are you from?
Cheers
Message 14 of 15
(1,129 Views)
@yljon wrote:
Where are you from?
Cheers
Netherlands.
Message 15 of 15
(1,106 Views)
