Split number from data string
I have user inputs like J1.A1 to J1.A20 I want to get the range from the given text 1 to 20,
Kindly share me the logic
Regards
Vikram Kumar P
(4,823 Views)
Accepted by topic author VikramShetty_p
I would use the Scan From String with the format set to "J1.A%d".  You will get the numeric value as an output.
(4,819 Views)
What is it that you are trying to do as a whole?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,769 Views)
I dont understand what is your exact requirement. But I can observe some informations from your post. I made a code snippet (Code made totally in an assumption) with that information. Check out the attached VI and reply.
(4,743 Views)
you mean you just want to extract the numbers?
(4,736 Views)
Thanks to all i got the solution by using scan from string %[a-z,A-Z]%d
Regards
Vikram kumar P
(4,723 Views)
What do you mean library? There is documentation on how the scan from string function works, and the codes to use for defining its operation. What more do you want/need?
Mike...
LabVIEW Champion
(4,590 Views)
