Split number from data string
I have user inputs like J1.A1 to J1.A20 I want to get the range from the given text 1 to 20,
Kindly share me the logic
Vikram Kumar P
(5,213 Views)
Accepted by VikramShetty_p
I would use the Scan From String with the format set to "J1.A%d".  You will get the numeric value as an output.
(5,209 Views)
What is it that you are trying to do as a whole?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(5,159 Views)
I dont understand what is your exact requirement. But I can observe some informations from your post. I made a code snippet (Code made totally in an assumption) with that information. Check out the attached VI and reply.
(5,133 Views)
you mean you just want to extract the numbers?
(5,126 Views)
Thanks to all i got the solution by using scan from string %[a-z,A-Z]%d
Vikram kumar P
(5,113 Views)
What do you mean library? There is documentation on how the scan from string function works, and the codes to use for defining its operation. What more do you want/need?
Mike...
LabVIEW Champion
(4,980 Views)
