Split an array following one column condition
Hi all,
I have a 2D array, and I would like to split this array into sub-arrays following 1st collum condition,
For example, the array is:
[1 a]
[2 b]
[1 c]
[2 a]
[2 e]
[3 h]
[5 t]
and we will need to split into  4 arrays below:
1st array:
[1 a]
[1 c]
2nd array:
[2 b]
[2 a]
[2 e]
3rd array:
[3 h]
4th array:
[5 t]
and so on,...
Please see the picture,
Thanks for your help,
Message 1 of 9
(2,657 Views)
Accepted by topic author tnn
Sort by the 1st column and then cut when the 1st column change value.
Qestit Systems
Certified-LabVIEW-Developer
Message 2 of 9
(2,616 Views)
There are multiple ways to achieve, please find the one quick approach.
Message 3 of 9
(2,614 Views)
Hi, Yamaeda,
Thanks for your suggestion,
I have finished it following your recommendation,
Message 4 of 9
(2,560 Views)
Thanks for your prompt reply,
However, If I follow that, I still cannot split the array,
Anyway, thank for your advice.
Message 5 of 9
(2,558 Views)
Hi tnn,
It always helps to simplify a VI:
Message 6 of 9
(2,539 Views)
Hi tnn,
why can't you "split the array"?
Which error do you encounter?
Where are you stuck?
(Why did you need to use OpenG?)
Suggestion:
Message 7 of 9
(2,534 Views)
Here's what I would do (you can skip the sort if you want the output sorted by first appearance of the key):
To get each of the three grouped arrays, just index into the output and unbundle.
Message 8 of 9
(2,492 Views)
Thank you all for your help,
I'm very appreciative of your suggestion,
This topic can be closed!
Message 9 of 9
(2,449 Views)
