Spinning LED values Clockwise
Hi TiTou,
Thanks for best advice!
My purpose was not to get readymade solutions form anybody. But needs to discuss the ideas which can solve my current as well as future isssues with customized controls.
Anyway thanks for great help to bring up good LabVIEW examples on Board.
Message 11 of 15
(1,679 Views)
I just found a vi that might help you using the picture control vis:
Draw arc.vi  see attached pic.
If you dig in the vi.lib/picture you can find even more usefull vis that are already there.
LabVIEW has a lot more than 'just' the vis in shown in the standard palettes Smiley Wink
Message Edited by Henrik Volkers on 04-12-2006 11:01 AM
Message Edited by Henrik Volkers on 04-12-2006 11:23 AM
Greetings from Germany
Henrik
LV since v3.1
Message 12 of 15
(1,650 Views)
And here is a short try to give you an idea
(somehow my last posting didn't make it ... during edit I added a vi and hit remove (old) attachement)
Funny, .. after this post It was there again, sorry for the repost.
Message Edited by Henrik Volkers on 04-12-2006 12:47 PM
Henrik
LV since v3.1
Message 13 of 15
(1,646 Views)
Thanks, Henrik.
Greetings of the Season.
Yes, I got your idea, now I will implement what I want.
Good Spirit!
Thanks again.
Message 14 of 15
(1,618 Views)
i have also a problem with rotating leds, I need to rotate an eight led matrix with a led turned on from left to right continuosly, but only with a shift register with true/false constants
I used a while loop, order 1D rotate array, and an array of leds as indicator. Finally, I use Labview 7.1.
Message 15 of 15
(1,267 Views)
