Speed problem on PXIe-6591 DRAM Acess
I have several megabytes in DRAM that are batch loaded.  Once done I need to walk sequentially through the addresses, retrieving the data.  I am working in a 156.25mHz SCTL.  It works fine and I get all the data, but very slowly (relative).  I do a very tight loop of two states.  One does the request and the other does the Retrieve and coverts the data and puts it into a FIFO.  The Retrieve takes hundreds of clocks for each valid data.  There are no other actors associated with the DRAM, I am the only one accessing it.
I found it by putting a counter on the number of clocks with valid/non-valid data.  I am in a very time (aka throughput) application.
(2,591 Views)
Are you using architecture similar to the example "Getting Started - External Memory.lvproj". you can find that in the NI Example Finder in LabVIEW at Help>>Find Examples.
The architecture in this would be good to study and potentially emulate to achieve faster DRAM access.
Brandon
(2,518 Views)
You need to quque up multiple requests to get anywhere near good throughput.  This is a typical "problem" with DRAM, the first address takes a lot longer than the subsequent addresses when queued.
(2,508 Views)
