Specify default destination directory
 II've created an installer using LabVIEW 8.5.1. When the user runs my installation it always sets the default installation path to be under c:\program files. I would like to be able to specify another default installation path. How do I do this in 8.5? Thanks!
(5,881 Views)
Hope this thread will solve your problem.
Post back if you have more queries.
Mathan
(5,875 Views)
Hi Jim,
You are going to need to change the Source Files Destination in the Installer Properties. LabVIEW built installers default to Program Files unless you manually change the settings here. Developer Zone Distributing Applications with the LabVIEW Application Builder.
Joshua B.
(5,839 Views)
Hi, I think I am having the same problem as Jim. I read the three links and was not able to find the answer I am looking for. In installer properties, source files category under the [program files folder] there appears another folder with the name of my application and the folder icon has a red check on it. This folder cannot be deleted or moved. I would like to move this folder under the [Windows Volume] folder.
Also, I feel that if I could change this then when I actually run the installer, the default installation directory would be C:\Application Name instead of C:\Program Files\Application Name.
I know that I can move all my files under the [Windows Volume] folder in the source files category. But I still cannot change what the installer thinks is the default installation directory.
Glen
(5,826 Views)
Found it!!! Right click..set as default. Then the folder under program files can be deleted.
(5,825 Views)
I have same question, trying to not use "Program File\Project Name" but use some path I pre-determine automatically. That means the user doesn't need to select new folder path for destination. I still don't know how. Can you help? Thank you so much.
(5,027 Views)
-During creation of installer in Destinations Page (Installer Properties Dialog Box): You can select one of the parent folder to set the tree structure and you can Add destination and select Set as default installation directory
-You can get more info on the options :https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/resource/framework/providers/builds/instal...
uday
(5,011 Views)
