Specified property cannot be set while the task is running.
I'm acquiring analog data and using DAQmx Trigger Property Node to pause the data input when one channel is below a certain value. I've set the Trigger's type as "Analog Level" by creating a constant on the block diagram. When I run the program, I get error #200557, "Specified property cannot be set while the task is running." I guess my questions are 1. If the type is set as a constant, why should the trigger try to set it while the task is running, and 2. How can I set this before the task begins as the DAQmx Trigger takes a task as an input.
Thanks for any help on this topic,
Aurora Tiffany-Davis
(3,721 Views)
Aurora
What the trigger property node actually takes is a task/channel input. Just wire the trigger property node before you call the Start VI and everything will be fine.
StuartG
(3,704 Views)
