Source Code of a LabView exe Program
Hello;
We use a program which was written in Labview. We wanna change the
program. But the extension of program is exe so we can not change the
program.
Is it possible learn the block diagram of it? If it is possible. how
can we learn block diagram?
I need your helps.
Thanks.
Message 1 of 12
(8,603 Views)
Once a LabVIEW program is built into an executable using the application builder, it is no longer possible to edit the program. All diagrams have been removed.
You need to contact the original programmer for the source code.
Message 2 of 12
(8,598 Views)
Unless you know who created the program and they are willing to give up the
source code, I'm afraid the short answer to your question is "no".
Clark Leach
Aut viam inveniam aut facium
LabVIEW 8.0.1; WinDoze XP
aut viam inveniam aut faciam
Message 3 of 12
(8,553 Views)
You need to approach the the creator/developer who is responsible
for that .exe. Its similar to building executables in other languages .
This is irreversible but you have an option in LabVIEW to run that
Exe . U can call that Exe while running it.
regards,
sundar,
Message 4 of 12
(8,526 Views)
Sundar,
I dont get your point.Smiley Sad What do you mean to say?
- Partha ( CLD until Oct 2027 🙂 )
Message 5 of 12
(8,521 Views)
Hey Patha,
You could call the Exe from Labview and also may be pass the arguments and parameters if enabled.
this VI does the function of executing an other Exe . you could find this in the connectivity tab / system exec.vi
regards,
Sundar.
Message Edited by SUNDAR.N on 11-23-2007 06:35 AM
Message 6 of 12
(8,512 Views)
OK... and how does this allow the person to retrieve the block diagram, which is what the poster was asking about.
Message 7 of 12
(8,488 Views)
Hi ,
one wouldnt be able to see or retrive the code behind the Exe but only run that exe with the help of this vi.
Message 8 of 12
(8,442 Views)
Sundar,
Still you ve NOT answered smercurio_fc's question, I think... Smiley Wink
Message 9 of 12
(8,424 Views)
Hi Partha,
I think I know what Sundar is talking about.
Prior to LV 8.0 You could write a VI in the same version as the exe and while the exe is running do a "get all VI's in memory".
From the names of the sbu-VI and the names of controls and indicators, guess at how the app works.
No, you can't get at the diagrams.
Ben
Message 10 of 12
(8,407 Views)
