Sound Generator
Hi folks .
I need a sound generator. However mi generator doesn't produce a continuous sound. Would you mind help me?
Thanks.
(9,517 Views)
Its generating fine on my PC here...
by the way have you muted your speakers?
Guru (CLA)
(9,502 Views)
Accepted by otipicni
Hi
Go to help in the toolbar then find examples, search for sound and locate the "Generate sound.vi" The Express VI is not made for generating continuous sound. By the way you should avoid using Express VIs. Using Express VIs is like peeing in your pants a cold winter day. You may get warmer for a few minutes. But after that it will be very cold.
Message Edited by Coq Rouge on 03-19-2010 09:34 AM
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(9,495 Views)
Thank Coq Rouge. That's what I was looking for (a continuous cound). In fact I want to produce white noise through my speakers in a frequency range (i'll use a bandpass filter) controlling the amplitude. Later I'll tell you my results. Thanks for the tip, although it's summer in my country Smiley Wink.
(9,464 Views)
Summer or winter, using Express Vis or walking around with wet pants is uncool (in the latter order):smileyvery-happy:. The clicking noise in the you got then using the Express VI. Happened because the sound output system is opened and closed every time you accesses the VI.
(9,451 Views)
'Sound' advice again from Coq Rouge 🙂
-AK2DM
(9,432 Views)
