Sound Detection
Does anyone know if there is a VI to do this
I would like to leave a microphone connected to the computer and if there is a noise in the room make a boolean true.
any help is appreciated
(5,671 Views)
see the attached VI
the concept is that first use the convert from dynamic data type to a 1d array of samples points to get the min max values when the mic is silent. now use this values as reference , if there is noise it will be out of these values . and a simple comparision to make the boolean true
with regards
(5,664 Views)
Thanks for the quick response and the example VI
when silence, i get values -0.00408936 or -0.0041198
and i get -0.003967 or -0.003936 when the noise event happend
do you think the mic is working OK
thanks
(5,656 Views)
Accepted by Carlos_Gonzalez
That example is only pulling a single value out of essentially a periodic array.  That will give very inconsistent results.  Attached is a VI that may work better for you.  Run it with no sound and a threshold of a couple hundred to get the normal background of your room.  Multiply your background by about 10% or 20% to add a little padding, then set this for the threshold.  Run and it should work.  Since you are looking for an impulse, the analysis is a simple peak-to-peak measurement.  If your background noise lasts very long, you may want to replace this with an RMS measurement to give you more noise immunity.
(5,631 Views)
thanks for the response.
I did not have time to try your VI, i will test it tomorrow.
What i am trying to do is to trigger a photo flash when a noise is captured by the mic. i hope your vi works
thank you
(5,605 Views)
