Sound Card Monitoring
I need a method of monitor the activity of the sound card. In other words,
I don't want to directly output or record anything, I just want to be able
to tell if there is something being output from the sound card, and also
control the microphone input volume. Anybody know how to do this?
(3,768 Views)
Hello Nate,
I used the Sound VIs (Functions >> Graphics and Sound >> Sound) to test what the sound card is doing. Basically, I dropped down a SO Config and wired the error out to a Simple Error handler. When the VI is run, the sound card driver will report an error (the device is already in use) if I try to configure it while it is in operation. You could monitor the Error out, and associate this specific error code with a "busy" sound card in your program.
For the Microphone input volume, I did not see an existing VI that controls this feature. I think that option is controlled by the sound card driver. I am not familiar enough with sound cards to know if this is an option that is programmatically supported. I know that you can achieve this functioanlity with o
ur DSA boards. I recommend that you check with the sound card manufactorer and see if you can call their driver from VB, or C++. If you can, then just compile the code into a DLL, and call the DLL from a Call Library Function inside of labVIEW.
Have a great day!
Joel Andersen
www.ni.com/ask
(3,768 Views)
