Sorting out 2D array by condition
Nice finding!
I'm taking part in a lab exercise and got those results as data. I thought to do analysis for the data with LabVIEW, although not required. I will check this matter, but I am trying to do the sum as mentioned before with legacy device but with no meaningful progress so far. Any lead you could give me?
Message 11 of 16
(1,408 Views)
Well, how about attaching the second datafile so we have something to work with?
Message 12 of 16
(1,400 Views)
Attached is the 2nd data file.
I tried to sort the arrays using the following sequence-
But I got weird values back. Input are both columns of frequencies and the common values should enter new array in the output.
Message 13 of 16
(1,391 Views)
Wouldn't it make much more sense to generate a suitable equally spaced linear frequency ramp, the use it to interpolate into the two datasets?
Message 14 of 16
(1,385 Views)
Your probably right, but how linearly set the between values?
Message 15 of 16
(1,382 Views)
Accepted by tomershtein
Here's one simple possibility. Do it for both input files and combine the data. (Note that you probably want to apply a slight smoothing filter before interpolation. Not shown)
Of course you can create any ramp you like.
Message 16 of 16
(1,375 Views)
