Solve
(2,367 Views)
Do you have a specific question?
We are not a homework service.
You need to attempt to do your own homework.  If you get stuck somewhere, then post a specific question about where you are stuck.
(2,332 Views)
  • I would not use Mathscript for this at all. All math can be done in pure G.
  • I would use a radiobutton indicator for the three LEDs. (Or even a single color LED, changing color and boolean text depending on input)
  • Your subject is "solve". All the math looks already solved, you just need to implement it. Did you get a starting template?
  • How far did you get on your own?
  • Do you have a specific questions regarding any of the listed points?
  • Where are the remaining pages?
(2,317 Views)
