Solenoid Control System
I have a solenoid, part number 527-1022-ND, that I need to hook up to an NI Elvis DAQ and an external power supply. I want to create a LabVIEW program that senses a sound input using a microphone and when a certain frequency is reached the solenoid will actuate, any suggestions of how to do this?
(2,658 Views)
You will definitely need some kind of amplifier or driver.  The solenoid requires 24 V at 0.6 A. If you have circuit design skills, building a driver with an inexpensive power MOSFET will not be too difficult.
Another possibility is some thing like the DRV102, also available from Digi-Key. You will still need to assemble the circuit and add some external diodes to protect the device from inductive spikes.
Lynn
(2,642 Views)
I want to connect the solenoid to a 6236B triple output power supply to power the solenoid and use a switch to control if the solenoid is active based on if a certain frequency is inputted into a microphone
(2,611 Views)
