‎06-11-2008 08:18 PM
>>Do you want the user to dynamically change the Process Variable?
In the simulation mode , yes!
In the real time process the PV will change in response to the output or atleast thats what is expected to happen.
‎06-12-2008 02:10 PM
Raghunathan,
It appeared that your original question related to an initial spike you saw when the set point was 5 and the process variable was 0. What this in your manual mode (which would spike to saturation without excitation) or when you tried to use it as a closed loop control system?
It might help at this point if you re-state your question just to ensure that we are on the same plane.
Thanks for your patience!
Cheers,
Jonah
Applications Engineer
‎06-13-2008 09:20 PM
Dear Jonah,
The spike was in simulation mode. I am now actually trying out the PID loop in an actual process and the loop seems to do the job. The process of fine tuning is under way and will revert.
