Smoothing
MrLearners wrote:
This is the screenshot of the graph block diagram.
So where do you still have problems? The filtered data you show in the small snippet looks fine and there is no inversion. In fact simulating your graph using the unfiltered data ptbypt in a loop gives about the same result. (see attached)
Message 11 of 20
(3,064 Views)
In fact, all you need is a chart as follows:
Message 12 of 20
(3,062 Views)
Hi Altenbach,
I am not sure why I am having this problem. You see in this image, the value is not even close. Is it normal, or perhaps this filter dosen't work for me?
Message 13 of 20
(3,046 Views)
What do you get if you run the VI that I have attached above?
Message 14 of 20
(3,024 Views)
Hi Altenbach,
I used your method in my code and run it. The image is what I get, in the graph there is only 6 pts. In the data I attached previously, there is 52 pts. The filtered data and unfiltered data differ alot.
Message 15 of 20
(3,011 Views)
You only show 6 points, not 52. You still did not tell me if you get a reasonable result by running my example with the default data that is already in it. I am trying to figure out if the algorithm or defaults have changed.
Would it be possible to attach the actual data (52 pts) that you think does not work well.
Message 16 of 20
(2,994 Views)
Hi Altenbach,
Message 17 of 20
(2,987 Views)
Im not a filter expert but I have gotten very satisfactory results in the past using the median pt by pt filter
(using a rank of 2 or 3.)
This usually maintains the original shape of the curve without too much data loss.
Message 18 of 20
(2,981 Views)
What is a "pt value"?
A point-by-point approach typically always lags a little bit, because it only has one-sided information and cannot predict points that haven't been measured yet.
Message 19 of 20
(2,971 Views)
Hi Altenbach,
Here is more data,
Message 20 of 20
(2,961 Views)
