Smooth XY Graph
How can I plot a xy-graph from measured data without a pixel hop as the following picture?
I tried to setup Y-scale, but it did not help.
(3,545 Views)
Accepted by topic author funmelody
I think you will need to use a pencil.
The graph is made up of pixels and your screen and video driver are probably not setup to display anything smaller than one pixel changes. Your graph is probably 300-400 pixels in the vertical direction, so a change of 0.2-0.3% in the value being graphed will move to the next pixel.
You might be able to draw thick lines with the picture control and keep track of where the pixel changes occur, but it would be a lot of work for little benefit, I suspect.
Lynn
(3,538 Views)
Thanks for a good explanation
(3,489 Views)
