Single loop iteration to store data
would it be a good practice to use a while loop with:
  • its condition terminal forced to TRUE,
  • uninitialized shift register
The idea is to store information useful to a VI only, and avoid adding a shift register to the while inside main vi.
I have attached two VIs as example.
(3,553 Views)
Accepted by nstjean
What you are trying to do was already done years back and it became a standard practice. Check about the Action Engine
(3,540 Views)
It's rather ironic that your suggestion is actually the opposite of what your sig states.  😄
Bill
CLD
(Mid-Level minion.)
(3,523 Views)
thank you for the Action Engine link.
I now know that using "USR" is a good and standard practice.
(3,490 Views)
In the spirit of 's sig, I gave you a kudo for your original post because I thought it was pretty awesome that you thought it out by yourself.  😄
Bill
CLD
(Mid-Level minion.)
(3,452 Views)
