Showing results forĀ
Search instead forĀ
Did you mean:Ā
Single Precision Float
Can any one help?
I  see the SGL icon which converts a number to Single Precision Float.
But I cannot see how to convert a 32 bit Single Precision Float back to a number.
Message 1 of 15
(6,874 Views)
Do you by 'number' mean some integer? A float is a number. šŸ™‚
If so, It's any of the to Ixx or Uxx functions. The most common one would be to I32.
Qestit Systems
Certified-LabVIEW-Developer
Message 2 of 15
(6,869 Views)
I may have it all wrong. The SGL icon is on second look probably not what I need.
What I a looking for is to convert to and from a number in IEEE-754 Floating Point.
the number input could be any real number.
Message 3 of 15
(6,850 Views)
I think a valid question here - perhaps even a better one is, "Why do you have to do this?"
Bill
CLD
(Mid-Level minion.)
Message 4 of 15
(6,846 Views)
SGLs represent "real numbers" (quantized to their inherent binary resolution). There is nothing to "convert".
You really need to explain the problem better. What do you define as "real number" in the above sentence:
  • A numeric in one of the other representations (DBL, etc.)
  • A flattened string representing the bits in the four bytes of a SGL (given correct endian-ness)
  • A ASCII formatted string showing the number in human readable text consisting of characters 0..9, a decimal delimiter, and maybe an exponent delimiter?
  • Something else?
Message 5 of 15
(6,829 Views)
Convert to and from what IEEE-745? As all the floating point numeric types below are IEEE-745 types.
=== Engineer Ambiguously ===
Message 6 of 15
(6,795 Views)
And if it isn't obvious from the table that RTSLVU posted, LabVIEW Sgl is IEEE-754 Binary32, LabVIEW Dbl is IEEE-754 Binary64, and LabVIEW Ext is IEEE-754 Binary128.
Many of us "standardize" on Dbl for Reals.
Message 7 of 15
(6,774 Views)
john@crane wrote:
Found solution at:
There is no way we could have known that this is what you are looking for. You never mentioned "binary" or "boolean" anywhere here.
Re-reading your questions, you wanted to "convert a number" (and never explain what you mean by that!). Your link shows how to convert properly formed boolean arrays (representing 32bits) to a SGL. Who would have guessed!? 😮 Boolean arrays are not "numbers" by most definitions!
Message 9 of 15
(6,730 Views)
As an FPGA programmer, I am not sure how to feel.... šŸ¤”
Message 10 of 15
(6,689 Views)
