Simultaneous Execution of Events
Hi. I've constructed a VI using event structure. The problem I have is when I'm pressing a button, I cannot press other buttons to work simultaneously(For example, when I press "w" to throttle, I can't press "d" to yaw). Is there any way I can change that? Please advice.
Message 1 of 14
(4,084 Views)
-Should be problem with unchecking the Lock front Panel until event completes when creating event.
-I cannot see vi can you post in 2012 using File>>Save for previous version.
uday
Message 2 of 14
(4,071 Views)
Hey here's my vi in version 2012
Message 3 of 14
(4,061 Views)
Did you try Uncheck lock front panel untill event finishes while creating event??
uday
Message 4 of 14
(4,056 Views)
Oh yeah I did but it didn't work.
Khairil
Message 5 of 14
(4,051 Views)
Please check for all events 😛
uday
Message 6 of 14
(4,041 Views)
Didn't work either. Smiley Very Happy
Khairil
Message 7 of 14
(4,029 Views)
example using key up and down events and storing the key states in an array.
Message 8 of 14
(4,016 Views)
Now, i understand. In key down event, whatever key pressed will be fed into case structure which means, after pressing 'w' when you press 'd' then it will go to case 'd' and increase that value only.
uday
Message 9 of 14
(4,006 Views)
-Please check the solution provided by altenbach(guru of labview for me :P)
http://forums.ni.com/t5/LabVIEW/key-down-in-event-structure/td-p/2193858
-Infact code shows how to identify two buttons simultaneous press events, you can use same logic here also.
uday
Message 10 of 14
(3,977 Views)
