Simulation Interface toolkit not working
I am working on a simulation and control problem using LABVIEW and Matlab. I have installed the simulation interface toolkit. But, the SIT server is not running. I have added the lines:
"addpath('C:\SimulationInterfaceToolkit'); NISIT_AddPaths; NISITServer('start',6011);"
in the matlabrc.m file. The NI SIT blocks are available in the simulink library. When I start matlab, the line:
" SIT: Added paths for Simulation Interface Toolkit 2011" appears. But the lines: "Starting the SIT Server on Port 6011 SIT Server started" don't show when matlab starts. I am attaching the Matlab startup screen.
Please help me out with this.
Thank You
(3,980 Views)
did u solve your problem I have the same issue???
A.Hakim
(3,735 Views)
No
(3,728 Views)
OK I solved )))
Try the follwowing:
1- uninstall Labview and Matlab and the simulation interface toolkit (SIT) (be sure that u have only one version from SIT)
2- If you are going to use SIT 2011...then you will need Labview 2011 for sure and Maximum version of Matlab 2010 I think.
Revise the combatibility of SIT with Matlab on google
Be sure to use MATLAB 32-bit version
hope it will help
thanks
A.Hakim
(3,720 Views)
