02-21-2013 02:39 AM
My colleague is making wonderfull XY charts and she can color the plot itself as a function of a third parameter.
Is there a way under Labview to do the same??
Thank you for answers
Julien
02-21-2013 03:42 AM
Julien,
the LV graphs only support a single color per plot.
You can split up your plot into several and use a XY graph to place each plot in the correct "slot" with it's appropriate color. But looking at your attached image, this will be quite cumbersome for your graph.....
Norbert
02-21-2013 03:58 AM
Hi Mr_J,
See may be you cant create exactly same chart but you can make not less than that also.
Something like this
02-21-2013 04:11 AM
Hi Julien,
there is no direct way to do it, but here is an example how to acchieve it anyway:
I hope this helps,
RMathews
02-22-2013 01:25 AM
Thank you for your answers,
I will try your solution RMathews but will use simple XY for everyday working and keep to send the data to my colleague .
Julien
