Simulation Interface Toolbox: Problems using sbRIO with Tutorial: "Using the Example Sinewave Model with a VxWorks CompactRIO Target"
Hello
I faced a problem when I tried to do the Tutorial "Using the Example Sinewave Model with a VxWorks CompactRIO Target".
My specifications are:
Software:
Win7 64-bit
Matlab 2010b with RTW (to compile the *.dll) (32-bit)
GNU-Toolchain 6.3 running in Virtual PC-XP-Mode (to generate the *.out)
Labview 2011 with Simulation Interface Toolbox 2011 (32-bit)
Hardware:
sbRIO-9631 (from Labview Embedded Platform Evaluation Kit)
I was able to compile a dll and an out file.
I created a custom fpga-Bitfile with the Tutorial "Creating a Custom FPGA Bitfile".
In a blank VI I made the Host-VI and with the SIT Connection Manager I created the Driver VIs.
Until here everything worked fine.
Now my problem appeared. As long as I don't create Hardware I/O Mappings my model runs fine on the sbRIO:
But when I try to map the in and out port of the model to a HW I/O I get this error:
What causes this error?
On my sbRIO following software is installed (followed this instruction: Configuring a Real-Time Target to Run the LabVIEW SIT Server)
Best regards
Patrick
(5,366 Views)
Hi Patrick,
please post the driver VI so I can see why you can't run it.
Best regards
Suse
______________________________
Certified LabVIEW Developer (CLD)
(5,303 Views)
I have exctly the same issue. here is my error
my fpga for the bitfile
bitfile.PNGmy driverVI
and my installed software
(5,083 Views)
did you try a repair of the NI-SIT?
Is there any lock in MAX?
Did you modify driver VIs?
Best regards
Suse
(5,051 Views)
Yes. In fact that was the first thing i did
(5,044 Views)
